No. The safest way for you to run more boost without upgrading to larger injectors is to get a FPR. This way you can run more pressure through the fuel system based upon boost. Before my FPR, i would spike 19pbs and 16 at redline and my A/F's were high, like 12.5:1. With the FPR, i was sooo pig rich with the same setup, that I had to actually clamp my voltage around 4 volts (11psi) to get the injectors to stop spraying so much.DrEdSrT4 said:Does the mapclamp make it safe for you to run high amounts of boost without upgrading to bigger fuel injectors? Like would I be able to run 20lbs safely on Stage 1
