1 - 3 of 3 Posts
· Registered
i have the agp wg at 17 psi will i throw a check engine light and if so someone told me to remove the tip senser ....... is this true and if so where is it.?
please be easy i am new to this (i have searched)
· Registered
the tip sensor is in the left front fender area by the stock airbox.you dont actually remove it though.(its the sensor with the white vac line going into it)if you cap the red line on the up pipe the tip will not read boost and no longer set off the cel
1 - 3 of 3 Posts
