Installing a MBC looks sounds and is very easy, but for noobs like I was b4 I tried putting it on.. this can be a little confusing.
Things to have handy
1. Extra Vac line, 1/4" from Advanced Auto for less than a dollar a foot is fine
2. Zip ties.. small black will look best
3. Some type of snips
Ok lets get started.. make your life easier and take the intake off and you MIGHT want to wait till your car cools because the turbo will melt your face off
1. Figure out which line you would like to tap into. You could use the green line or your blue line. IT REALLY DOESNT MATTER. GREEN is supposed to be for torque and BLUE for horsepower, but the end result is your car is really fast
2. You could try and cut into the lines as close as the WGA as you can to save from using 20 feet of vac hose. A simple cut and placement of a vac "T" will do fine. HOWEVER, you may get rid of that blue or green line altogether, cap it off at the boost solenoid and run the straight line to the MBC. Its all the same don't let it confuse you.
3. After you place that "T" in the line, run some of your vac hose to the MBC. Since that is your turbo source run it to the SIDE of the boost controller. Take some more vac hose and run it to your WGA from the BOTTOM of the BC. Zip tie all your loose ends and your done.
Tuning
When tuning your setup you will want to set the amount of boost for your supporting mods such as S1,2,3 or fuel management.
1. If you are a stock 03 I would not up your boost anymore than stock
2. If you are a stock 04 you might be able to get away with an extra psi or so
3. Just get stage 1 so you can SAFELY up the boost to about 17-18 spike and holding about 15-16. Its all preference. HOWEVER with S1 anything over 18lbs will pull your timing and you are working against yourself!
*HINT* If you have an aftermarket WGA I.E. AGP billet style. Make sure you install that on your car AND TUNE IT before you add your MBC. If you plan on tuning both at the same time you are going to go crazy..I did that and quickly removed the BC and just tuned the wga.
To tune the WGA you must loosen the nut on the left and turn the corresponding nut on the right either UP towards your car for raising the boost or DOWN towards your engine for LOWER boost.
To tune the MBC all you have to do is raise or lower the boost with the allen key provided. If it is a regular MBC then it will only have 1 mechanism. If it is a HPBC it will have 2. The bottom one is for drastically changing your boost and the side one is for a more precise boost setting. Both will raise and lower boost just one more so than the other.
Always carry that allen key on you because you might notice your boost is to low or high where ever you are. I'll try to update with some good pics when I find them
Tuning
