LittleMT said:Let me guess, a LS1 SS v6!!!!!
How do gears=no top end? Especialy on a race to 120? I could see like 150 when he would need to go into 5th,but 120? With a 7k redline I assume he can hit 120 in 4th.Nolimits said:Why only 95 mph? Thats not even a 1/4 mile (unless your running high 14's) Ohh yeah, its cause you got gears and gears = no top end. Why dont you race that Camaro to 120 and see where your at then.
You are correct sir.GotWhat? said:How do gears=no top end? Especialy on a race to 120? I could see like 150 when he would need to go into 5th,but 120? With a 7k redline I assume he can hit 120 in 4th.
CKT said:Because the track was marked off to approx. an 1/8 mile fucksauce. My car can still hit the speed limiter (154) in 5th with the 4.10's. Buy a Tiburon.
CKT said:I stay away from those WSV6's. I knew once I got past 85 MPH it was in the bag. 85 MPH>LS1
LS2 Powered said:you trap 95 in the 1/8th????
out of curiosity (please nobody else interject) what are your 1/4 mile ETs?
90s13coupe said:it took gears and et streets to beat the 273 geared camaro. :LAME: :smilie_ha
I bet the RSX-S was a much closer race seeing as how it has 4.77 gears.CKT said:I also beat an 04 GTO and a RSX-S :w00t: yesterday. Lost to a Cobra (twice).
they should be beatin and have there keys taken away from them....thats patheticDrEdSrT4 said:ive seen LS1s with bolt ons run 14.1 and 14.3s all night,
CKT said:No actually I trap about 87 , thats why I wrote the track was approx an 1/8 long. It's an airport runway that is used for dragracing once a month and is supposed to be marked off at an 1/8 mile. I've run a 12.87 @ 106.6 with this current set-up. I've only run once since the gears went in and I didn't abuse it to bad because they only had around 150 miles on them at that point. My best with the 3.55's was 12.88 @ 106 so there is certainly room to improve my ET's with some aggressive driving.
Just to be the bearer of factual information and not the bullshit that gets thrown around here a lot, the SS had 3.42s if it was a 6-speed (only gear available) or 3.23s if it was automatic (this ratio was optional on the Z and formula but standard on the SS and WS6.)Whats funny is any LS1 kill story on any site yeilds that same weak ass responce. 3.42's are such a rare option in F-bodies, and if it did have 2.73's it's not my fault GM put such a suxor rear gear in them. And lets also touch on the fact that you assume the SS was stock. There are so fucking many stock 3-5 year old SS Camaro's out there This one had at least aftermarket exhaust, other than that I couldn't tell you. I also beat an 04 GTO and a RSX-S yesterday. Lost to a Cobra (twice).
