i second that notion...srtjay said:did you seal between the tb and adapter? sounds like you are leaking boost there
yes. but I did not put a seal between the adapter and the intake minifold, I just out the stock o ring on it....srtjay said:did you seal between the tb and adapter? sounds like you are leaking boost there
10 minutes.srtjay said:i don't think you should lose 2 psi. i think you are leaking boost some where.. do a boost leak test. could be your cold side pipe, or the adapter/tb.. you shouldn't have to put any kind of sealer on the adapter/IM, thats what that o ring is for. how long did you let the sealent dry for?
