03-04 Sx/srt - Hard Codes
P0016-crankshaft/camshaft Timing Misalignment
P0031-o2 Sensor 1/1 Heater Circuit Low
P0037-o2 Sensor 1/2 Heater Circuit Low
P0032-o2 Sensor 1/1 Heater Circuit High
P0038-o2 Sensor 1/2 Heater Circuit High
P0033-surge Valve Solenoid Circuit
P0068-manifold Pressure/throttle Position Correlation
P0071-ambient Temp Sensor Performance
P0072-ambient Temp Sensor Low
P0073-ambient Temp Sensor High
P0107-map Sensor Low
P0108-map Sensor High
P0111-intake Air Temperature Sensor Performance
P0112-intake Air Temperature Sensor Low
P0113-intake Air Temperature Sensor High
P0116-engine Coolant Temperature Performance
P0117-engine Coolant Temperature Sensor Low
P0118-engine Coolant Temperature Sensor High
P0122-throttle Position Sensor #1 Low
P0123-throttle Position Sensor #1 High
P0125-insufficient Coolant Temp For Closed-loop Fuel Control
P0128-thermostat Rationality
P0129-barometric Pressure Out-of-range
P0131-o2 Sensor 1/1 Voltage Low
P0137-o2 Sensor 1/2 Voltage Low
P0132-o2 Sensor 1/1 Voltage High
P0138-o2 Sensor 1/2 Voltage High
P0133-o2 Sensor 1/1 Slow Response
P0139-o2 Sensor 1/2 Slow Response
P0135-o2 Sensor 1/1 Heater Performance
P0141-o2 Sensor 1/2 Heater Performance
P0171-fuel System 1/1 Lean
P0172-fuel System 1/1 Rich
P0201-fuel Injector #1
P0202-fuel Injector #2
P0203-fuel Injector #3
P0204-fuel Injector #4
P0234-overboost Performance
P1106-baro Solenoid Performance
P1188 Tip Sensor Performance
P0243-wastegate Solenoid Circuit
P0300-multiple Cylinder Misfire
P0301-cylinder #1 Misfire
P0302-cylinder #2 Misfire
P0303-cylinder #3 Misfire
P0304-cylinder #4 Misfire
P0315-no Crank Sensor Learned
P0325-knock Sensor #1 Circuit
P0335-crankshaft Position Sensor Circuit
P0339-crankshaft Position Sensor Intermittent
P0340-camshaft Position Sensor Circuit
P0344-camshaft Position Sensor Intermittent
P0420-catalytic 1/1 Efficiency
P0440-general Evap System Failure
P0441-evap Purge System Performance
P0442-evap System Medium Leak
P0443-evap Purge Solenoid Circuit
P0452-nvld Pressure Switch Sense Circuit Low
P0453-nvld Pressure Switch Sense Circuit High
P0455-evap System Large Leak
P0456-evap System Small Leak
P0461-fuel Level Sensor #1 Performance
P0462-fuel Level Sensor #1 Low
P0463-fuel Level Sensor #1 High
P0480-cooling Fan 1 Control Circuit
P0481-cooling Fan 2 Control Circuit (non-turbo)
P0481-cooling Fan 2 Control Circuit (turbo)
P0498-nvld Canister Vent Valve Solenoid Circuit Low
P0499-nvld Canister Vent Valve Solenoid Circuit High
P0501-vehicle Speed Sensor #1 Performance (auto Trans)
P0501-vehicle Speed Sensor #1 Performance (manual Trans)
P0506-idle Speed Low Performance
P0507-idle Speed High Performance
P0519-idle Speed Performance
P0508-iac Valve Sense Circuit Low
P0509-iac Valve Sense Circuit High
P0513-invalid Skim Key
P0516-battery Temperature Sensor Low
P0517-battery Temperature Sensor High
P0522-oil Pressure Sensor Low
P0551-power Steering Switch Performance
P0562-battery Voltage Low
P0563-battery Voltage High
P0572-brake Switch #1 Circuit Low
P0573-brake Switch #1 Circuit High
P0581-speed Control Switch #1 High
P0582-speed Control Vacuum Solenoid Circuit
P0586-speed Control Vent Solenoid Circuit
P0594-speed Control Servo Power Circuit
P0600-serial Communication Link
P0601-internal Memory Checksum Invalid
P0622-generator Field Control Circuit
P0627-fuel Pump Relay Circuit
P0630-vin Not Programmed In Pcm
P0632-odometer Not Programmed In Pcm
P0633-skim Key Not Programmed In Pcm
P0645-a/c Clutch Relay Circuit
P0660-manifold Tune Valve Solenoid Circuit
P0685-asd Relay Control Circuit
P0688-asd Relay Sense Circuit Low
P0700-transmission Control System
P0833-clutch Released Switch Circuit
P0850-park/neutral Switch Performance
P1105-tip Sensor Solenoid Circuit
P1115-general Temp Sensor Performance
P1189-tip Sensor Circuit Low
P1190-tip Sensor Circuit High
P1593-speed Control Switch Stuck
P1602-pcm Not Programmed
P1603-pcm Internal Dual-port Ram Communication
P1604-pcm Internal Dual-port Ram Read/write Integrity Failure
P1607-pcm Internal Shutdown Timer Rationality
P1696-eeprom Memory Write Denied/invalid
P1697-emr (sri) Mileage Not Stored
P1854-tip Baro Out Of Range
P2074-manifold Pressure/throttle Position Correlation
- High Flow/vacuum Leak
P2096-down Stream Fuel System 1/2 Lean
P2097-down Stream Fuel System 1/2 Rich
P2302-ignition Coil #1 Secondary Circuit-insufficient
Ionization
P2305-ignition Coil #2 Secondary Circuit-insufficient
Ionization
P2503-charging System Voltage Low
U0101-no Transmission Bus Message
U0155-no Cluster Bus Message
U0168-no Skim Bus Messages
U110c-no Fuel Level Bus Message
