I recently installed a PnP intake mani and a kinetic 60mm tb
when i put everything back together, the wires ripped out of my IAC, but they are still intact with the copper connectors on the ends of the wires...
i put them back in the sensor connector and everything was back the way it should be, and the wires seemed to be making a connection, so i started the bad boy up... well the car shot straight up to redline.
im currently throwing two codes... P0508 and P2074
Which are for intake mani pressure, and the other is for the IAC
is one related to the other? if the IAC isnt working, it wouldnt shoot to redline right? cuz all the problems i have seen with the IAC make the car stumble and stall cuz its not letting air get past the throttle plate
a couple people told me its a vacuum leak, but everything is hooked up the way it should be and all the lines seem fine, but are the two codes related?
wtf?!?!
wtf?!?!
