I haven't seen it posted here yet.
The Un-Official Mopar Parts List
STAGE UPGRADE PACKAGES
Mopar SRT-4 Stage 1 [2003] (P5007862, $399.00)
-527 cc/min Injectors (Mis-Printed)
-577 cc/min Injectors (Corrected)
-Stage 1 PCM
Mopar SRT-4 Stage 1 [2004] (P4510592, $399.00)
-Stage 1 PCM
Mopar SRT-4 Stage 2 (P5007863, Under $2,000.00, December 2003 - February 2004)
-682 cc/min Injectors
-Stage 2 PCM
-Upgraded Wastegate Actuator
-3.0 Bar MAP Sensor
-3.0 Bar TIP Sensor
-2.5" Cat-Back Exhaust System (Required but Sold Serperately)
-Turbo Toys Hardware and Components
--Dial-a-Boost (4-pos Thumb-wheel)
--Intercooler Sprayer (w/ switch)
--Pump vs. Racing Fuel Switch
--All necessary wiring, switches and mounting hardware
Mopar Stage 3 [FULL] (P5007864, Early-Mid 2004)
Mopar Stage 3 [Add-On to Stage 2] (P4510256, Early-Mid 2004)
-Stage 3 PCM
[email protected] Upgrade Turbo Unit
--16% larger compressor wheel diameter to flow and compress more intake air
--19% larger turbine wheel diameter to flow more exhaust gas and reduce back pressure
--67% more turbine scroll area for reduced back pressure
-High Flow (75psi) Viper Fuel Pump Module
-Demand-Regulated Fuel Rail Assembly
Mopar SRT-4 Stage 3-R (Under Development)
-Stage 3R PCM
-719 cc/min Injectors
-Cat Delete Exhaust (Race Pipe)
-Other
Watch-Out For Future 'Staged' Upgrades (Under Development)
STAGE UPGRADE ITEMS SEPERATELY
Mopar SRT-4 Stock 2003 525 cc/min Injectors (4852747AA)
Mopar SRT-4 Stage 1 527 cc/min Injectors [Mis-Printed] (N/A)
Mopar SRT-4 Stock 2004 577 cc/min Injectors (4891574AB, $55.85)
Mopar SRT-4 Stage 1 577 cc/min Injectors [Corrected] (4891574AB, $55.85)
Mopar SRT-4 Stage 2 682 cc/min Injectors (Early 2004)
Mopar SRT-4 Stage 3 719 cc/min Injectors (Middle 2004)
Mopar SRT-4 Stage 1 PCM (P4510592, $399.00)
Mopar SRT-4 Stage 2 PCM (Early 2004)
Mopar SRT-4 Stage 3 PCM (Middle 2004)
Mopar SRT-4 Stage 3R PCM (Under Development)
Mopar SRT-4 Upgraded Wastegate Actuator (Early 2004)
Mopar SRT-4 3.0 Bar MAP Sensor (Early 2004)
Mopar SRT-4 3.0 Bar TIP Sensor (Early 2004)
Mopar SRT-4 Turbo Toys Hardware and Components (Unknown Potential)
Mopar SRT-4 [email protected] Upgrade Turbo Unit (Mid 2004)
Mopar SRT-4 High Flow (75psi) Viper Fuel Pump Module (Mid 2004)
Mopar SRT-10 Viper Fuel Pump (5086489AA, $550.00)
Mopar SRT-4 Demand-Regulated Fuel Rail Assembly (Mid 2004)
Mopar SRT-4 2.5" Catback Exhaust (P4510461, $385.00)
Mopar SRT-4 RacePipe [Cat Delete Exhaust Part] (Under Development, 2004)
SUPENSION UPGRADES
Mopar SRT-4 Front Strut Tower Brace (Under Development)
Mopar SRT-4 Rear Strut Tower Brace (Under Development)
Mopar SRT-4 Stage 1 Performance Springs Kit (P4510458)
Mopar SRT-4 Stage 1 Front/Rear Anti-Swaybar Kit (P4510454)
Mopar SRT-4 Stage 2 Suspension Kit [KW Coilover Kit] (P4510447, $1,395.00)
Mopar SRT-4 Stage 3 Suspension Kit [KW Adjustable Coilover Kit](P4510586, $1,625.00)
SEATING UPGRADES
Mopar and Katzkin One Row, Uninstalled, Premium (Leather1PU, $699.00)
Mopar and Katzkin One Row, Installed, Premium (Leather1PI, $1,035.00)
Mopar and Katzkin Two Row, Uninstalled, Premium (Leather2PU, $999.00)
Mopar and Katzkin Two Row, Installed, Premium (Leather2PI, $1,465.00)
Mopar and Katzkin Two Row, Uninstalled, Deluxe (Leather2DU, $849.00)
Mopar and Katzkin Two Row, Installed, Deluxe (Leather2DI, $1,299.00)
GUAGE UPGRADES
Mopar SRT Air/Fuel 2-1/16" Ratio Gauge (P4510435, $75.60)
Mopar Silver Air/Fuel 2-1/16" Ratio Gauge (P4510444, $75.60)
Mopar White Air/Fuel 2-1/16" Ratio Gauge (P4510426, $74.53)
Mopar Carbon Fiber Air/Fuel 2-1/16" Ratio Gauge (P4510416, $76.80)
Mopar SRT Boost 2-1/16" Gauge (P4510525, $211.86)
Mopar Silver Boost 2-1/16" Gauge (P4510526, $211.86)
Mopar White Boost 2-1/16" Gauge (P4510420, $209.60)
Mopar Carbon Fiber 2-1/16" Boost Gauge (P4510410, $215.20)
Mopar SRT Fuel Pressure 2-1/16" Gauge (P4510434, $251.33)
Mopar Silver Fuel Pressure 2-1/16" Gauge (P4510443, $251.33)
Mopar White Fuel Pressure 2-1/16" Gauge (P4510425, $254.26)
Mopar Carbon Fiber Fuel Pressure 2-1/16" Gauge (P4510415, $257.60)
Mopar SRT Nitrous Pressure 2-1/16" Gauge (P4510436, $236.26)
Mopar Silver Nitrous Pressure 2-1/16" Gauge (P4510445, $236.26)
Mopar White Fuel Nitrous 2-1/16" Gauge (P4510427, $233.86)
Mopar Carbon Fiber Nitrous Pressure 2-1/16" Gauge (P4510417, $239.73)
Mopar SRT Tachometer 2-1/16" (P4510437, $119.73)
Mopar Silver Tachometer 2-1/16" (P4510446, $119.73)
Mopar White Tachometer 2-1/16" (P4510428, $119.73)
Mopar Carbon Fiber Tachometer 2-1/16" (P4510418, $119.73)
Mopar SRT Oil Pressure 2-1/16" Gauge (P4510431, $71.86)
Mopar Silver Oil Pressure 2-1/16" Gauge (P4510440, $71.86)
Mopar White Oil Pressure 2-1/16" Gauge (P4510422, $70.13)
Mopar Carbon Fiber Oil Pressure 2-1/16" Gauge (P4510412, $76.26)
Mopar SRT EGT 2-1/16" Gauge (P4510430, $161.46)
Mopar Silver EGT 2-1/16" Gauge (P4510439, $161.46)
Mopar White EGT 2-1/16" Gauge (P4510421, $160.80)
Mopar Carbon Fiber EGT 2-1/16" Gauge (P4510411, $161.46)
Mopar SRT Voltmeter 2-1/16" Gauge (P4510433, $47.60)
Mopar Silver Voltmeter 2-1/16" Gauge (P4510442, $47.60)
Mopar White Voltmeter 2-1/16" Gauge (P4510424, $45.73)
Mopar Carbon Fiber Voltmeter 2-1/16" Gauge (P4510414, $52.00)
Mopar SRT Water Temperature 2-1/16" Gauge (P4510432, $54.53)
Mopar Silver Water Temperature 2-1/16" Gauge (P4510441, $54.53)
Mopar White Water Temperature 2-1/16" Gauge (P4510423, $52.80)
Mopar Carbon Fiber Water Temperature 2-1/16" Gauge (P4510413, $58.93)
Mopar SRT Tachometer 5.0" (P4510429, $305.60)
Mopar Silver Tachometer 5.0" (P4510438, $305.60)
Mopar White Tachometer 5.0" (P4510419, $257.33)
Mopar Carbon Fiber Tachometer 5.0" (P4510409, $318.26)
Mopar SRT Guage Pod 2 1/16" Dual Pod A-Pillar Mount (P4510559, $37.80)
Mopar SRT Guage Pod 2 1/16" Single Pod A-Pillar Mount (P4510560, $37.80)
Mopar O2 Sensor Kit [Required For Use w/ Mopar Air/Fuel Gauges] (P4510599)
Mopar Tachometer Signal Adapter [Required For Use w/ Mopar Tachometers] (P4510598)
LIGHTING UPGRADES
Mopar SRT-4 SilverStar Headlight Bulb [9007] (P0009007ST, $27.00)
Mopar SRT-4 FogLight Bulb [89x Series] (N/A)
TRANSMISSION UPGRADES
Mopar SRT-4 Limited-Slip Differential ['03 Upgrade, Quaife] ($1400, P5007923)
Mopar SRT-4 Limited-Slip Differential ['04 Replacement, Quaife] ($1900, 5127732AA)
Mopar SRT-4 Limited-Slip Differential Installation Kit ['03 Upgrade] (P4510588)
Mopar SRT-4 Upgraded Flywheel (Under Development)
Mopar SRT-4 Upgraded Half Shaft
-Stage 1 PCM
-Stage 1 PCM
-Stage 2 PCM
-3.0 Bar MAP Sensor
-3.0 Bar TIP Sensor
-Stage 3 PCM
-Stage 3R PCM
-Other
SUPENSION UPGRADES
SEATING UPGRADES
GUAGE UPGRADES
LIGHTING UPGRADES
(Under Development Early 2004)
(Under Development, Early 2004)
Mopar SRT-4 Upgraded High Torque Clutch (Under Development, Early 2004)
Mopar SRT-4 Short Throw Shifter (P4510485, $119.00)
Mopar SRT-4 Stock Shifter Knob (0XF701ZAAA, $19.99)
Mopar SRT-4 Stock Shifter Boot (05029Z57AA)
Mopar SRT-10 Stock Shifter Knob (SG081X9AA )
Mopar SRT-4 Upgraded Shift Knob (Under Development)
MISC UPGRADES
Mopar SRT-4 BOV Conversion Kit (P4510548, $69.00)
Mopar SRT-4 Cold Air Intake (N/A, Not Recommended)
Mopar SRT-4 Red Powder Coated Valve Cover (P4510367)
Mopar SRT-4 Yellow Powder Coated Valve Cover (P4510368)
Mopar SRT-4 Silver Powder Coated Valve Cover (P4510370)
Mopar SRT-4 Black Powder Coated Valve Cover (P4510369)
Mopar SRT-4 Blue Powder Coated Valve Cover (P4510371)
Mopar SRT-4 Cermanic Coated Valve Cover (P4510270)
Mopar SRT-4 Polished Valve Cover (N/A)
Mopar SRT-4 Carbon Fiber Valve Cover (N/A)
Mopar SRT-4 Ceramic-Coated Intake Manifold (P4510551)
Mopar SRT-4 Carbon Fiber Fog Light Accent (Soon)
Mopar SRT-4 Carbon Fiber Hood Scoope Accent (Soon)
Mopar SRT-4 Turbo Timer (Unknown Potential)
Mopar SRT-4 Underdrive Alternator Pulley (Under Development)
Mopar SRT-4 Underdrive Alternator Belt (Under Development)
MANUALS & SERVICE EQUIPMENT
Mopar 2004 Performance Parts Catalog [Street Essentials] (P4510652, $3.95, PDF)
Mopar 2004 Performance Parts Catalog [Muscle Essentials] (P4510654, $3.95, PDF)
Mopar 2004 Performance Parts Catalog [Speed Essentials] (N/A, N/A, PDF)
Mopar Neon Performance Modifications Book [350 Pages] (P4876667)
DCX 2003 Dodge Neon Service Manual (8127003028, $110.00)
DCX 2003 Dodge Neon Service Manual on CD (8127003028CD, $90.00)
DCX 2003 Dodge Neon/SRT-4 Chassis Diagnostic Procedures Manual (8127003010, $3.00)
DCX 2003 Dodge Neon/SRT-4 Transmission Diagnostic Procedures Manual (8127003011, $7.00)
DCX 2003 Dodge Neon Powertrain Diagnostic Procedures Manual (8127003013, $16.00)
DCX 2003 Dodge SRT-4 Powertrain Diagnostic Manual (8127003014, $9.00)
DCX 2003 Dodge Neon Body Diagnostic Procedures Manual (8127003012, $8.00)
DCX 2003 Dodge SRT-4 Supplement Service Manual (8127003028A, $15.00)
DCX 2003 Dodge SRT-4 Owner's Manual (810260334, $10.00)
DCX 2004 Neon Service Manual (8127004028)
DCX 2004 Neon Service Manual on CD (8127004028CD)
DCX 2004 Neon/SRT-4 Chassis Diagnostic Procedures Manual (8127004010)
DCX 2004 Neon/SRT-4 Transmission Diagnostic Procedures Manual (8127004011)
DCX 2004 Neon Powertrain Diagnostic Procedures Manual (8127004013)
DCX 2004 Dodge SRT-4 Powertrain Diagnostic Manual (8127004014, $9.00)
DCX 2004 Neon Body Diagnostic Procedures Manual (8127004012)
DCX 2004 SRT-4 Supplement Service Manual (8127004028A)
DCX 2004 Dodge SRT-4 Owner's Manual (810260434, $10.00)
DCX DRB-III Aftermarket Package, Includes CH6020A-PCUD (CH6020A-AM, $6,053.75)
DCX DRB-III Remote Update and Flash Reprogramming (CH6020A-PCUD, $2,458.75)
MISC UPGRADES
