when i hook up my volt guage it constintley stays on even wen the keys are a mile away, wut does this mean? i took it out. is the volt guage supposed to stay on?
for now, strip the end of the wire and wrap it around the power window fuse (the fuse lid you take off has the fuse key on it) then put the fuse back in with the power wire, if it works, your done. make sure you have it grounded, and not to the batterymikegtdyno said:how do i get to the ignition sorce, or the fuse, cause i was lookin in the manual of the car and i got to the fuses but i ddint no were to go from there
Broken5hift said:no the fuse panel in your dash. open up the drivers side door, right against it on the front dash is a fuse panel. thats where you need to do it too. take out the fuse from that panel (make sure its a fuse for power windows or radio) and then wrap the wire around the fuse connectors (metal tabs) and place fuse back into slot.
:wave:Nismo300ZX said:
if the gauge is a three wire yes, if its a two wire the power wire already contains itmikegtdyno said:ooo ok i see now do i do the same for the lighting blulb in the guage ?
Broken5hift said:if the gauge is a three wire yes, if its a two wire the power wire already contains it
yea...that and RELENTLESS FLAMEING....:evil_laugBroken5hift said:no prob man, thats what we're here for
N20Jeep said:yea...that and RELENTLESS FLAMEING....:evil_laug
