20lbs?! no way.. and 18 stock, that sounds more like a broken boost gauge lol.. with S1 when my car was @ 160 degrees on its best night couldnt get anything over 16spike.. if ur gauge isnt bad then reset ur PCM.. ive never heard of a S1 pcm boostcontrolled car boosting 20lbs.. need a MBC for thatMetsSFTF said:I am basicly stock (stage 1) and on friday I was hitting 20psi in 4th, but then quickly dropped to about 15 then down to 12
When I was stock I would still hit 16-18 psi spikes and usually hold to about 11-12
HOLY SHIT 18.. thats ridiculous.. defeats the purpose of a MBCptperformance said:I had seen 18 all the time on my 05 it would drop quick to 15 and most of the time it would hold to 13 at redline. Sounds a little low to me, need to do a boost leak check.
After 30k your car has to be leaking like a siv. Pcv valve needs to be changed, ic pipes need to be pressure checked and tightened, tranny fluid needs to be changed, plugs and wires should have been changed if not need to be done, mopar bov needs to be thrown for distance, filter on your aem prolly needs to be cleaned and recharged, and a bunch of other things that prolly need to be addressed that I can't think of...Alex47 said:i m boosting between 11-13psi and all i have is an AEM short ram mopar BOV and MSD. Does that sound like normal boost?![]()
Clever quote.BlackDragon said:...mopar bov needs to be thrown for distance...
