hozay09 said:
Ever since I had it installed in my car I haven't seen shit difference. Still the same temps.
Strange....
I have to wonder if it ever got installed?
I just installed one in my 2004 Eblue which was running a average of 205 degree's and would jump to 210... Much hotter then my Red SRT.
The 180 cured this problem, the car now will rarely see 200, then it dips down to about 190. It also takes the car longer to warm up to a normal operating temperature..
You should have seen something....
Install is very simple, simply remove the bolts on the filler neck, I recall them be 10mm, have rags ready to absorb coolant that might spill out...
the thermo sits in a rubber seal which holds it into place, remove and install in the same manner making sure that you don't put the tstat in upside down..
bolt on filler neck then top off with coolant...
