you're stock and wot shifting? i used to miss third all the time too...get a sts, you won't be sorry.
You go to put the shifter into the 3rd gear location and it doesn't go in. Happend all the time with the stock shifter.dannya88 said:what does missing 3rd gear mean?
YIKES.. PwN3d..in a bad wayGrifter said:Hass STOP WOT shifting!!
My friend had the same problem, the next week on the way to work the car wouldn't shift at all......he grenaded his trans.
Yup, true story. The mechanic that took out his trans said that when he removed the drain plug there were chunks of metal that came out. FYI, the tech owns an SRT.DrEdSrT4 said:YIKES.. PwN3d..in a bad way*knocks on wood*
I rarely do it.. i dont even do it at the track.. ive only done it a handful of times just to get it right while im racing.. the one to 2nd and 4th is cake but to 3rd took sometime to get.. but the feeling is awsome..Grifter said:Yup, true story. The mechanic that took out his trans said that when he removed the drain plug there were chunks of metal that came out. FYI, the tech owns an SRT.
Anyway, I have never and will never WOT shift in my car. That's obviously my opinion, but after rebuilding transmissions in class I would hate to be those syncros.I would do it only if it was my weekend race car and I could afford to beat on it like that.
It does sound cool though.![]()
And I will most likely do it wrong...BlackDragon said:wot shifting only does damage when you do it wrong...
